RE: error on remote gsu
As Rick said, the cables can be swapped, all of the data cables that came with your turbine can be interchanged.
Do NOT use a cable from the Radio Shack or something, they are wired differently.
It is very easy to make your own cables but you need a special crimping tool.
If that does not cure it, then your thermocouple is bad. I THINK JetCat USA sells them seperately now and you can change it out at home if need be.
Regards,
