RE: Anyone using nylon hinges without glue?
I do what campy does but use A spray oil. Then I started using Pacer Hinge glue instead of CA, I never have used epoxy, Gorilla glue A time or two. I used to always drill through the wood on one side and through the hings and slightly into the wood on the other side of the hinge then just squirt some thick CA into the hole. I stuck tooth picks through that hole and let the glue set up. Cut off the tooth pick and sanded flat. Never have had A hinge come loose. The pacer hinge glue works great and if you get some glue on the hinge it just snaps off when you flex the hinges. Water also removes it before it sets.
If you think the screws are A good idea then go for it, why bother asking?
