RCU Forums - View Single Post - Stalling Engine :(
Old 08-23-2008 | 01:22 PM
jrock0012's Avatar
jrock0012
Default RE: Stalling Engine :(
Adjust your idle screw, you should have a 1-2mm opening in the carb when at idle, take your air filter off and look inside of the carb and make sure you have the proper gap, when you release the throttle the gap closes completely and your car stalls.....hope this helps
