RCU Forums - View Single Post - Ed Kazmirski's Taurus
Old 08-23-2008 | 01:55 PM
  #552
UStik
Default RE: Ed Kazmurski's Taurus
Oh, I forgot you're drawing your Taurus, not Ed's. Sorry, I thought you would duplicate the position of the old proportional servos.
I meant the two fuses in Africa could have been slightly different even though Dennis Hunt said the two models were identical. I just can't believe that Ed built two identical models, and the two fuses may look rather similar. We can't really see that in the crate picture.
BTW, looking at the attached picture I even think there are balsa pieces put later in front of leading edge and behind trailing edge (not only onto the wing saddles). And maybe Ed removed the old rails for the reeds servos and that gave the (tool) dents and the impression of a coarse build (even the piece of foam behind the tank is damaged). The old rails were higher in the fuse so with the lower propo rails the old switch holes were covered, hence the two new holes lower and aft of them.
And an addition as well: The unswept wing and the swept wing seem to have slightly different root chord lengths, but the unswept wing seems to be longer! This was against my expectation but could be true, even though these measurements from pictures are rather unreliable. This could mean the leading/trailing edge pieces were added when the swept wing came in use.
