RCU Forums - View Single Post - E-Flite F-15 Eagle
Old 08-23-2008 | 03:06 PM
  #57
patrick randall
Default RE: E-Flite F-15 Eagle
I destroyed a 3 blade fan using a high KV motor on 4S. I think the revs were just to much for a cheap fan.
Yes more cells and the higher voltage available will mean (if used) higher amp draw. Always stay within the max C rating of your cells unless you want to shorten their life by an alarming factor. See the FMA direct site for white papers on this if you are interested.
I flew with the cones and did get a bit higher speed but the vertical did suffer. You can make up more robust cones from X-ray film or overhead transparency material. I personally want good vertical so fly without at the moment. The (small frontal ram effect) inlet ducts and overall drag of the F-15 airframe are limiting factors. If you want to go faster get something with better ducting and more powerful fan potential or a bungee/no wheels job. This is just a parkflyer foamie don't forget! The retracts sold it to me. Great fun.
My 2c
Patrick
