burshless set up help!
okay ive been running my losi 1/10 Xcelorin 7500Kv Brushless Combo for a while on my grupner jet boat set up, and its been working fine since. but recently my aftermarket esc watercool fried my esc up = [. now im looking for a new esc. but i dont want to spend another $130 on a new one from horizonhobby. i dont realy know about brushelss stuff too much. the original esc & motor specs are
ESC Specs
Type: Sensorless Brushless
Forward: Y
Reverse: Y
Brake: Y
Time Delay Brake: Y
Throttle Limiting: Y (adjustable in 10% steps)
Programmable: Full (via quick program card or PC)
Continuous Maximum Current: 100A
Momentary Peak Current: 540A
Input Connector Types: Losi EC3 style
Dimensions (WxLxH): 1.16 x 1.54 x 1.3 in (29.5 x 39 x 33.2mm)
Weight: 1.7 oz (48 g)
BEC Voltage: 6.1V, 3A
PWM Frequency: Optimized for Spektrum or traditional radio systems
Motor Specs
Bearings or Bushings: Precision ball bearings
Voltage: NiMH 6-12-cell; LiPo 2-3-cell
RPM/Volt (Kv): 7500Kv
Weight: 6.35 oz (180 g)
Overall Diameter: 1.4 in (35.8mm)
Shaft Diameter: 0.125 in (3.17mm) with flat
Shaft Length: 0.18 in (4.6mm)
Overall Length: 2.15 in (35.8mm)
it says Continuous Maximum Current: 100A and Momentary Peak Current: 540A does that mean to be able to run the same motor i have, i would need the same continuous & peak amps????????????????????
im looking through ebay right now and found this one [link=http://cgi.ebay.com/RC-boat-brushless-motor-ESC-w-water-cool-60A-max-380A_W0QQitemZ140259247905QQihZ004QQcategoryZ34058 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]ebay link[/link]
the specs are
Model Sea King 60A
Con.t Current 60A
Burst Current 380A
resistance 0.0007 ohm
Working Voltage 4-12cells NiCad or Nimh / 2-4cell lipo
BEC output 6v/1.5a
Weight 32g
would it work? i dont wana fry another esc.
