RCU Forums - View Single Post - Blade 400 PNP Help Pls
Old 08-24-2008 | 11:43 AM
bart.tech
Default Blade 400 PNP Help Pls
Hello all.
Just moved up to blade 400 from cp pro. I have followed the recomended advanced set up as per eflite. I have the radio (DX7) set up as outlined in the blade 400 manual. The problem I am having is after one and a half minutes of non idle up hovering the head speed decreases (soft voltage cut out of esc i am asumeing). If i land and place throtlle to off it takes off with normal power agin for 20-60 seconds the goes back into cut off.
I am using 2 tp 3S 2200 v2 batteries and both act the same. When charged they show 1900 to 2200 miliamps. I am really hoping for more than 90 second run times (lol but uneasily). I did have to do alot of head set up out of the box. Wouldnt even lift off at 3/4 throttle as set up.It hovers really nice now at just over 1/2 throttle. All help would be apreciated.
Bart
