LT-40 ARF Balance vs engine
Thanks, maybe I don't need to bother with the K&B....
Mine is not together yet, If you look at the top post, I was trying to find out how the plane balances. I'm trying to get it finished for this w/end.
The good thing about this plane is that the tank is on a shelf with room unerneath for the battery. That will help if more nose weight is needed. I'm also going to be using a 2" alu spinner.
Hows it fly on the 4 stroke? I've got an ASP .52 I could use....
I had someone do the trim flight on my Hobbistar and that took off straight, just needed a bit of right aileron for level flight. As long as it balances correctly, I might do the maiden myself this time....
