RE: Blade 400 PNP Help Pls
My speed control is this one [link]http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLA325H[/link]. Not shure if instructions are the same.I can keep my pinky on all components for 10 seconds. As far as head set up the blade pitch with swash at 16.25mm as per instructions was -5 ,5 ,+15.
I adjusted it to -10 0 +10. The belt was so tight I could not deflect it at all. I set it so the tail would skip when turned and then tightened until it would not skip anymore. I found some head set up vids on you tube. Full of good info and seemed to work well. I will loosen up the gear mesh and retry tommorow. Both my batteries act the exact same and they are brand new tp3s2200v2 25c. Batteries require 1900-2200 milliamp charge (acording to my tp610c). This seems to verify that the batteries are depleated after a flight of 2 mins. thanx Bart
