RCU Forums - View Single Post - Blade 400 PNP Help Pls
Old 08-24-2008 | 07:16 PM
bart.tech
Default RE: Blade 400 PNP Help Pls
Ok new developement. Hovered in non idle up until soft cut off. Shut down immediatly. Installed fresh battery and repeat. Charge both batteries and they took less than 1000milliamps. I think the esc set up may be the issue but manual for plug and play and rtf model does not offer much help. I will call horizen tommorow and see if 25 amp heavy duty esc instruction apply to stock blade 400 esc. Thanx to all bart.
