Hacker x AXI x E-flite in a Divo
Hi guys.
This afternoon I was trying to fly my Sobré, when my motor (AXI 2212/26 Silver version) started to burn.
I don't know the damage size, but I believe I lost the motor, the speed and the battery.
I am about to start to assembly a Divo to outdoor flights and right now I don't know what motor to get.
My experience is totally with AXI motors and I love it. I am just wondering about to try something new.
I want to stay around the AXI 2208/34 + Jeti 12A wheight and try to get more performance.
So what motor would make me more happy?
- Hacker A20-26M (150W)
RPM/V 1130
Weight 42g (1.48oz) Peak Amps Prop Peak Watts
Shaft Diameter 3.0mm
Battery 3 LiPo / 800-1300mah
Operating Current(Amps) 12 amps
Peak Amps 20
Prop 9x4.7
Peak Watts 150
- E-FLITE Motor outrunner PARK 370 BL Brushless 1360Kv
Type: Brushless Outrunner
Size: Replacement for 280/370
Bearings or Bushings: Bearings
Recommended Prop Range: 8x6 to 10x4.7 2-Cell or 8x3.8 3-Cell
Voltage: 7.2 - 12
RPM/Volt (Kv): 1360 Kv
Resistance (Ri): .10 ohms
Idle Current (Io): 1.00A @ 10V
Shaft Diameter: 3.17mm (1/8 in)
Overall Length: 25mm (1.00 in)
Weight: 45g (1.6 oz)
Overall Diameter: 28mm (1.10 in)
Diameter: 28 mm (1.1 in)
Length: 25 mm (1 in)
Continuous Current: 12A
Maximum Burst Current: 15A (15 sec)
Cells: 6-10 NiCd/NiMh or 2-3S LiPo
Speed Control: 10 - 20 Amp Brushless
- AXI 2208/34
Voltage range 6-10 cells
2-3xLi-Poly
RPM per Volt 1,080 RPM/V
Max. Efficiency 81%
Max. Efficiency Current 4-7 A (>74%)
Max. loading 8 A / 60 s
No load Current / 8V 0,35 A
Internal resistance 260mohm
Dimensions 27,7x26 mm
Shaft Diameter 3,17 mm
Weight 45 g
Recomended model weight 200 - 500 g
If you guys tell me to go for E-flite or Hacker, what speed control and prop should I use with them?
