RCU Forums - View Single Post - OS 91 FX Trouble
Old 08-24-2008 | 11:40 PM
42etus's Avatar
42etus
Default RE: OS 91 FX Trouble
Prime the engine by putting some fuel directly into the carb, maybe 10-15 drops. Then try to start it. If it still won't at least fire on the prime, you may have something assembled wrong. Check that the glow plug isn't burned out. Put your finger over the carb, open the throttle all the way and turn the engine over by hand. That should draw fuel from the tank into the carb.
Paul
