RE: Tamiya TG-R
Alfa Romeo. TRF with the exact same engine and setup as the Clarion. OS18CV-RX is a decent basher engine. This car is backup for when I put the other one under a tire.
Mercedes CLK. This is my drift car. The motor has a cooling fan that sucks air from a hole in the chassis under the car. Perfect for low air flow and full throttle. Wheels are cast solid.
Porsche GT1. This is my TGR Driver. I run it with only the scale vent hole cut in the body. It has full electric start and glow. The TGRs have the engine closer to center, so you can flip the pipe over the back. On the TGR, the pipe has to run down the side with a tube run back.
Sonax Mercedes. My rear drive basher. It has a gyro on the steering servo. Makes you appreciate AWD.
Some unstarted projects. I may never get to them.
