RCU Forums - View Single Post - Ed Kazmirski's Taurus
Old 08-25-2008 | 04:51 AM
  #571
Taurus Flyer's Avatar
Taurus Flyer
Default RE: Ed Kazmurski's Taurus
Evan,
In what place Dennis lived when he did make his Taurus for Africa?
In what place Ed lived when he did make his Taurus for Africa?
About my plane Evan, look at the wing, no straight TE and look at the horizontal tailplane, silk covered!
So, what you wrote:
>>>>>>>>>>>>&g t;>>>>>>>>>>>> >>>>>>>>>>>>&g t;>>>>>>>>>>>> >
The model you are drawing was built sometime after Africa and before the 1963 World Champs, not a lot of time, hence the rather rough build of the original
Is not true.
When it is finished, I will make pictures of it in the same position as the Taurus on the right side of the crate because I do want to show you that this Taurus fuse is the fuse in the crate but also the fuselage of auction 2 and of the carrier.
And a point that's more important, it will fly much better than my other Taurus, less resistant, lighter and better shape, think about the story of the backside with inverted flight.
I will experience the difference between the Top Flite cargo Taurus and the Ed Kazmirski contest Taurus I think.
But that's the interesting part of our hobby.
Evan, I often did use the expression "As old as the way to Rome".
You may axplain the Romans what you mean with :"hence the rather rough build of the original"!
Cees
ID:	1018935   Click image for larger version
