RE: test running on ground
A wattmeter will pay for itself in short order. For instance, a motor may be recomended to pull 10 amps sustained full throttle. You choose a prop to get as close to that # as you can without going over. without the wattmeter you may be way underpropped and not getting the full poop out of your motor, or if you go over, you may toast the motor.
