ORIGINAL: 3D_Junkie
So what's your suggestion for the OMP 92" hybrid. I did not include right thrust when installing the motor mount. Should I plan on adding washers under the motor mounts or leave it the way it is.
You can certainly add the right thrust with washers under the left side mounts or the more elegant way is to program right rudder with throttle. The more experienced pattern flyers will do this and tailor the curve to the aircraft and setup.
