RCU Forums - View Single Post - Prop hard to tighten
Old 08-25-2008 | 09:56 PM
jollycub
Default RE: Prop hard to tighten
Hi Greg, great catch. I sprayed brake cleaner into the threaded part of the hub and and the cleaner poured out of the holes used for tightening the spinner. Then I put some after run oil on the threads of the spinner. I put the spinner on the prop shaft and and I was able to hold the prop and tighten the spinner. Thanks a bunch. by the way, it was a Dubro spinner.
