RE: Which servos
Brian yes you just screw the servos right to the mounting brackets of the SS
you will want to get the servos as far forward as possible, don't glue the wing mounts or anything that slides on the fuse untill you are sure you have your CG figured out
then only use a drop at the front and rear of the mounts, this will allow them to break free in a crash and not break your CF fuse
