RCU Forums - View Single Post - Intermittent Throttle
Old 08-26-2008 | 08:16 AM
newandy
Default Intermittent Throttle
What i have
AXE CP
GY401 with the c12 ESC
dx7 with AR6000
Here are the connections:
1. BAT port - not connected
2. THR - connected to ESC/3 in 1
3. AILE - connected to Right Rear Servo
4. ELE - connected to Front Center Servo
5. RUD - Connected to Gyro
6. GER - Connected to Gyros sensitivity switch (yellow wire)
7. AUX - connected to Left Rear Servo
I connected everything up and found a thread on the forums on how to setup the dx7. I set it all up and it all looked good. Now it was time to test with the motors connected. When I turned it on the tail seemed to work fine but to main rotor was intermittent. I would give it a little throttle just to get the blades to spin and it would start and stop continuously. Can anyone help?
