RCU Forums - View Single Post - Prop question
Old 08-26-2008 | 12:32 PM
alfredbmor's Avatar
alfredbmor
Default RE: Prop question
ORIGINAL: Ken4
Which is better? 12x6 prop pulling 11,100rpm or 13x6 prop at 8,900rpm? My OS 56 alpha is spec for both. OS website specs 1.0hp at 10,000rpm and practical rpm range 2,400rpm to 13,000rpm. Using it on a Fliton Votec 351. Plane seems to be faster with the 12x6prop (but that could be my imagination cos its noisier too). But its so cool flying with the 13x6, I can see more trail of smoke from the plane! Comments appreciated.
I would use the 13 x 6 prop. I do believe that it has more torque than the 12 x 6 that could be loosing performance at a high rev. number. A quicky plane could be better with the 12 x 6 but your Fliton plane is not designed for speed so the 12 x 6 prop will not give a sustantive gain. Fliton creates more aerobatic planes, then you will need a bigger mass of air in your surfaces so the 13 x 6 could be the best.
