RE: Glow Plug Life Expectancy
I have some engines that have been with the same plug for over 4 years, but I have an engine (ASP .61) which some time ago was running inverted and blow several plugs in the same season, I really do not know why, maybe the after run oil (transmission fluid) or something else, the fact is that I decided to change the position of the engine to a 90 degrees set up and solved the problem.
