RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 08-26-2008 | 09:05 PM
  #96
kahloq's Avatar
kahloq
Default RE: CMP BF109F BUILDING THREAD
Its a 2.4ghz JR rx, so no EMF wont be an issue, however, I will be installing a 36" remote extension in the 2nd plug on the main rx though just to be safe.
The chin scoop will be opened up where the stupid black fake sticker is. This will blow air directly on the esc and is the reason i put the esc where it is. I noticed JE Johnson replied before I was able to submit this post so this answers his questions
I am still working on getting more throughput for air from the front area to the battery compartment to expel as much air as possible. I will also attempt to make the dummy exhaust stacks functional(to the point of opening them up to allow air to get out).
The esc is not blocking any stock hole in the bulkhead either so its not covering anything plus I drilled addtional holes in that bulkhead...one is directly behind the esc and one to the left of it.
