RE: Positive wing incidence
Woodie, mjfredrick, flyncajun and anybody else with Genesis experience:
Can you post your CG location relative to the LE at the root of the wings (to save my mathematically challenged brain from having to sort out the numbers in a formula)? My Genesis wings were from a different source and the wing tube might not be in the same location as what comes from CA. The numbers Woodie has and mjfredrick says are similar to his, are quite a bit forward from the tube than what mine used to be. I say used to be because I have not checked it since doing some repairs (to the fuselage in front of the wing) * spent way too much time trying to get engines to run reliably.
Measurements in relation to the LE at the root would be useful for me. Thanks!
Tom
