RE: ECU Burn-out problem
Craig,
you want to be as close as possible to the exit of the ECU, as Mr. Matt has stated the Turbine end is already protected, ideally the protection diode would be soldered directly on the MOSFET transistor on the PC board; however you may not want to do this for obvious warranty situations.
Rich
