Hey man, that's cheating. [:'(]
Just use the original bow MG, plug up the LED hole, drill out the original barrel or use a section of aluminum or brass K&S tubing and drill the cooling holes...
That's taking the easy way out. [
ORIGINAL: brel
thanks, where can I get a dummy machine gun for the hull to replace the pathetic set up so that the led is in the gun instead of below it
