RCU Forums - View Single Post - Rubber bands on Avistar
Old 08-28-2008 | 11:56 AM
goirish's Avatar
goirish
Default RE: Rubber bands on Avistar
ORIGINAL: hogflyer
ORIGINAL: goirish
Is there a correct way to install the rubber bands?
Leading edge to trailing edge generally works better than leading edge to leading edge, and trailing edge to trailing edge…………
Hummmmm!! leading edge to leading edge-going across huh. Does it make any difference when you criss-cross?
Sorry Irish, just couldn’t resist that one.
I do a mix – start with Leading edge to trailing edge, then a crossing pattern, and back and forth alternating each pair.
Hogflyer
