RCU Forums - View Single Post - Difference between A3 and #8 plugs??
Old 08-28-2008 | 04:28 PM
n19htmare
Default RE: Difference between A3 and #8 plugs??
ORIGINAL: Jburry
I've used 8's and a3's in my 46AX and noted no real difference in performance. The 8 seemed to last slightly longer. I run 15% omega, and the engine turns very fast (16-17K in the air), yet the 8's last more than a gallon for me.
J
Am I reading this right???
First of all, what prop are you spinning at 16-17K on the 46AX?
Second of all, more than a gallon...how much more? . If you're only getting 1-2 gallons per plug something is WRONG.
I'm still on the A3 that came with my first AX46. I have broken in 2 engines with this plug, I've run maybe 5 gallons on it and am still using it.
