RE: 4th gen A-10 by Mibo jets
Back to the gear issue ... you guys may think this is overkill, but I am setting my mains up on one air system and the nose on a separate air system, using a valve for each. These are big cylinders and with forward retraction and big doors the gear have to pull with them, I'm not sure that you can get too much air to the cylinders. Here is a pic of the removable module I made ... if anyone needs it, I can produce the parts in short order on the CNC router.
