RE: When to remove small paint stencils?
I use PPG deltron for all my planes Matt and if your getting bleed through then you're most likely having 2 problems
1. the vinyl your using is no good or your not applying it well
2. your spraying on the paint too thick
I usually spray and then remove the mask right away if it is small or about 5 minutes afterwards. I never let i dry fully.
