ORIGINAL: blitzkrieg65
ORIGINAL: dyeager535
I know the ones made by someone else were not as tall, but from what's been posted, other than engine placement these gear boxes appear no different than the earlier HL ones. Since the hull shouldn't be different, nor the back of the upper hull from the PIII, not sure why they would have changed them at all.
The "low profile" boxes built by whoever I believe were made to accomodate the airsoft.
I aked Bill that same question and he said that the top Hull sits lower then the P-III so they had to lower the motor, and yes they just added a bracket so you can service it and moved the pinion point, same gear ratio!
The Blitz
PS I grew up in Washington hope to move back there in about 5 years!
You still need the low profile gearboxes to make room for the gun "breech" recoil mechanism, or whatever, as the high mounted motor in the PIII gets in the way. There shouldn't be any difference in the hull top height.
Jo
