RCU Forums - View Single Post - Question on my 9C using Hitec digitals and rates, etc.
Old 08-30-2008 | 07:12 AM
Flyboy1958
Default Question on my 9C using Hitec digitals and rates, etc.
First off, in the end point screen, should I be leaving my end points at 100% when using digital servos and programming the end points with my programmer? This brings me to my next question, should I be then first setting my High D/R at 130% to 140% in the D/R- Exp. screen to max out the resolution? ( I have been dialing up my end points to 130%-140% thinking I was *****g my resolution that way, and leaving my D/R at 100%) is that wrong? I then flip an assigned switch down for my low rates and dial my D/R from 100% to what it needs to be. I guess what Im getting at is, is this the screen that I should be initally dialing up my D/R to 140% max with high rates if I want to max out my resolution?
The next thing I am wondering now is this. I have been setting my end points at 130% thinking I will have room to play with and using my programmer to set my end points and find my neutral. This is when I went to the D/R screen and leaving my high D/R at 100% and dialing down my low rate to what it needs to be. Now Im thinking Im probably wrong, that it doesn't matter what I set my end points at in that menu if I am programming Hitec digitals and finding the end points with the programmer, right? I need someone to set me straight quick! Thanks
