RCU Forums - View Single Post - How to calaculate wing tube size needed?
Old 08-30-2008 | 12:53 PM
rcguy!'s Avatar
rcguy!
My Feedback: (69)
Default RE: How to calaculate wing tube size needed?
ORIGINAL: CrateCruncher
Sounds like you have your answer already but I just want to mention a couple of observations from the details given:
1) 15 g's amounts to a 15 ft radius pullout at constant 56mph [a=(VxV/r)+g] - is that enough?
2) There will be an abrupt change in wing stiffness at the rib bay where the tubes end resulting in stress concentration if not addressed. It can be reduced by reinforcing the spars in the first bay or two outboard of the tubes to smooth the transition in stiffness.
I'm just trying to add value to your conversation guys. I don't even know if this is a trainer or a low wing pattern ship or what power you intend. Those details will make a difference. Crate.
Yes additional load paths are being considered via spar caps. FWIW... 180MPH top speed, no 3D of course. Desinn at 20's is well covered with the preliminary main spar tube being investigated. I'll post determinations when finalized. Please keep the inputs coming!
Dave
