RCU Forums - View Single Post - Question about biplane
Old 05-22-2003 | 01:15 AM
vt_cruzer
Default Question about biplane
I'll check to see if the horizontal stab is level with the wings. As for the amount of throw the elevator has, I set it up by the intstuction manual. It didn't seem to have any problem with wanting to roll on takeoff, but then again I've only flown it twice and both times were for less than a minute...just long enough to see there was a problem and then fight it back to the ground. Both elevators move the same amount since they operate off the same pushrod. Could misalignment cause the problem that I'm having?
I've got an incidence meter that I've used to set up the plane, but I don't think its too accurate. I may go get one of those lazer incidence meters and see what it says. Next time the weather is good I'm going to try to fly it again and I'll let you know if your advice helped.
thanks
