RCU Forums - View Single Post - Question about biplane
Old 05-22-2003 | 01:21 AM
BenWillis
Default Question about biplane
NoOne,
Im not sure what the reccomended throws are on the GP Ultimate but on my DP event the low rate throw listed in my manual resulted in a snap when using full elevator for a loop, banked turn etc. Do you remember ow much elevator input you used whe attempting the turn? As you know normaly on take off you just feed in enough elevator to get a good climb rate. I would try another flight and when you roll right gie very little elevator input, see if this will turn the pane. If it does try thr turn again and give it full deflection. If the snap comes back you either need to dial down the throw or learn where the snap limit is.
Again, all of this is just from the experience I have recently had with my ultimate.
Ben
