RE: Help 401 and tail issue
Thank You for your responce. The tail had vary little damage ,but I did replace the tail boom becouse it had a little bend in it.The servo and the tail seem to work vary smooth. Im thinking that maybe the servo is over traveling the gyro, but not sure what to do about it? The limet switch is at its lowest point 60 and the linkage is set on the servo horn on the second hole from the tip.
