RE: Mvvs 58 crankshaft movment
HI!!
AS I said I my previous post, "EVO58X2 OIL", I flew my plane a lot this past week with motul 800 rr at 40:1
Last week I noticed that I had an axial play about 0.5mm, but this weekend I noticed that the play is about 1mm
the engine run fine, but I'm nervous the fly my plane, I'm afraid that somthing will break in the motor, I don't understand why a bearing
can cause this play, I don't see the bearing moving when I move the shaft and when the motor was new, he doesn't had this play
Why the fault is only to the front bearing???
thank!!
