RCU Forums - View Single Post - Very weird behavior of Extra upon elevator input
Old 08-30-2008 | 10:46 PM
plugin's Avatar
plugin
Default RE: Very weird behavior of Extra upon elevator input
ORIGINAL: bbbair
I cannot say for sure until you give me some more information about YOUR Extra.
BUT!
I have an Extra 300 that was a kit made in the ealy 1990s (another story) if our two AC have the same Elevator hook up I MAY be able to help you... (bear with me)
I have a single servo that uses a pushrod to a 'Y' arrangement to the TWO elevators.
- the servo is located on the right side of the fuse
- because of the location of the servo, the LEFT Elevator push rod is LONGER than the RIGHT pushrod.
- the servo action is circular and it only moves the elevators in a linear fashion for about 30 degrees (+/- 15) which is gentle flight.
When I EXCEED the linear motion of the servo the pushrod moves the left and right elevators at a different rate - and I get what appears to be some SLOPPY manouvers. [:'(]
MY Solution to this is to add a second servo and pushrod for the Left elevator and slave them together.
So what sort of Elevator arrangement do YOU have?
I do have the same setup you had although I thought about this before installing the servo so I have it in the middle. Both halves move equally throughout all the travel. I do want to use a second servo to be sure.
ORIGINAL: Stickbuilder
Sounds as if you are inducing a stall with the elevator. I have seen several designs that will really show this when you apply excessive elevator. If the plane tucks under and then departs the flight path on an opposite heading, this is what is happening. You will often find this occurring when on the downwind leg too. Your speed over the ground is high, but your relative airspeed is lower. You give aileron input, and the low wing is travelling slower than the top wing, and then you horse in the elevator, and away it goes. Try setting your elevator rates a little lower, and get used to not giving full stick commands. There is nothing wrong with your plane.
Bill, AMA 4720
WACO Brotherhood #1
I think this is what sounds like my problem. I can notice it only on the downwind turn so I figure this must be the answer. I still don't understand the aerodynamics behind what's happening. Why should the plane snap in opposite direction to where I'm turning? It's a fairly violent snap which in some cases gets the plane in totally the opposite direction.
ORIGINAL: Jester241
Your definetly stalling the wing. This is when the airflow around the wing is interupted for some reason(or something like that). My edge 540 does it all the time if I yank the elevator too hard in a turn. Theres really nothing you can do about it except not turn so hard. It can be VERY dangerous,so be careful. Its best to set your throws on low rates so that they wont exceed the limit that induces this stall effect. And then just be careful on high rates.
I thought of this originally but if this was the case, the plane would tend to fall towards the "dropped" side but it does the total opposite, it briefley returns to level flight and tends to roll to the other side.
I should add that if I fly level and apply full elevator, the plane wont climb but it rather does a weird "hop". It kinda drops the tail slightly and gets sluggish. Can't all this be due to a tail heavy setup?
