RCU Forums - View Single Post - Pullstart Woes
Old 08-30-2008 | 11:03 PM
ehroof
Default RE: Pullstart Woes
ORIGINAL: bonkas
After tuning my car for a bit I notice one of the pullstart screws has fallen out and one seems to be loose but I can not tighten as the screw is kinda stripped.
It looks like load of oil is leaking from the pullstart and I assume it's because the pullstart is not sealed as the scres have come loose.
Should I worry about this or just leave it until it falls off and have a excuse for a new pullstart as the cord is starting to get frayed.
I dont remember what car you have but you shouldnt have oil in your pullstart, if its a .21 or .28 and a rear exhaust you may have an exhaust gasket leak, if its a .16 or .18 and a side exhaust, your backplate may be loose or leaking, check the screws. I would replace that missing screw before you loose the pullstart, your lhs should have one for you.
