flywheel problem
So how do you suggest tightening it more? Also, I haven't put loctite on yet, should I try doing that too and see if it'll start spinning? Also, Is the flywheel supposed to be flush with the crankshaft? If so how do you thread the clutch nut on? I had my LHS cut the shaft for me, so it should we the right length....
