RCU Forums - View Single Post - Right thrust and 3D
Old 08-31-2008 | 01:28 AM
Ernie Misner's Avatar
Ernie Misner
Default RE: Right thrust and 3D
>>> Upright or inverted makes no difference whatsoever. >>>
A question for AFSalmon..... first, thanks for your experienced input and the link.
Now when inverted the vertical fin and rudder are hanging down below as you mentioned, but the propwash that causes pull to the left wouldn't exist anymore would it?
So if you had some right thrust built in for upright, wouldn't inverted be better off without it?
Thanks loads,
Ernie
