RE: Nitromodels, covering...
I put a Magnum .52 in the nose. Yanks it around with no problems. I was going to use my YS 63. I put that in the Giles 202 50 sized. The Saito 82 would pull it with no problems. Might be tight in the nose. It did come in just a little tail heavy with the 52 in the nose. I had to put the 5 cell 2200 mah battery behind the rear fuse former to get it to balance. May have to mount a servo or servos in the tail to get it to balance. I was tempted to mount (2) HS-65MG's in the tail for the elevators. Those servos should have plenty of power for the Fascination's elevator halves.
Dru.
