RCU Forums - View Single Post - 1/3 Scale J3 Cub - Engine Recomendation
Old 08-31-2008 | 06:25 PM
sfaust's Avatar
sfaust
Default RE: 1/3 Scale J3 Cub - Engine Recomendation
ORIGINAL: BalsaBob
Thanks for all the posts/information. I received my G62 today ...... and the wraparound inverted muffler. I am also using the 2 inch prop drive extension. It all fits nicely in the cowl (but I will have to cut a small hole one side to allow the carb to stick out a bit). Bob
Bob, or anyone for that matter, do you know where I can get the prop extension for the G62. I am converting a 1/3rd scale cub to use a G62 as the current engine is underpowered. It's obvious that I am going to need to move the engine back about 2" to make it fit in the cowl, so some sort of a prop extension will be required. Also, any recommendations on a muffler. I want something very quiet, and someone recommended a Slimline muffler.
