RE: help !!?!!??
You can put paper between the gears when you mesh them and it should be able to be pulled out, it should pass through when the gears are turned and leave a nice pattern on the paper. Just make sure the gears are not too far apart, the teeth should be making good contact, but that the gears are not grinding.
