Dual rate settings
Is it normal not to use a rate at maximum? I usually fly with a new plane with a dual rate radio DX7 set at Rate setting 1- 70% for rudder, ailerons, elervator than going to setting 2, after getting use to it, which for me is 125%, which I set into the radio. This Is usually good but do some planes need lower settings. I'm new to this but have one small plane that is real sensitive if the ailerons are set to 125 and the slightest extra lever movement causes it to go out of control. At a lower setting it is fine but do some planes require the setting to always be set lower and can't take a higher setting. All my other planes can handle the 125 setting. Thanks Ron
