Control Linkage Servo
Another tip on the nose gear linkage, make it so that the nose gear moves a very small amount, about plus or minus 10 degrees is more than enough. You can even get by with 5 degrees. Do this by connecting the nose gear push rod to the innermost hole on the servo arm and the rudder to the outermost hole.
