RCU Forums - View Single Post - Thottle servo glitches on Python Questions
Old 09-01-2008 | 12:24 PM
reyn3545's Avatar
reyn3545
Default RE: Thottle servo glitches on Python Questions
If you're seeing glitches... be SURE to get them under control, at any throttle setting, before you let this thing in the air! I had a similar problem on an AW 90-120 yak, thought I had it fixed, and found out the hard way that I was wrong. It turned out to be a bad ignition module, emitting too much RFI, but it cost me a plane to find that out.
If you're still running 72MHz, be absolutely sure to eliminate any interference... If your throttle servo is less than a foot from the ignition module... move it back! That plane's got plenty of room to mount the servo back, and you can use nyrod to get to the motor.
reyn3545 is offline
