Lithium cells
Dodgey99,
Forgot to say I posted this about my HLG200 you maybe interested or you may already have it sorted but here it is :-
"I had the same problem, basically from the front you want the orange wire to the right and you DO NOT connect the other two wires I cut mine. the reason I think is that otherwise the tail ESC will try and provide power to the receiver but this is already being done by the main motors ESC.
Also the manual that came with my HLG200 was for the HLG200 that comes in a proper plastic case but mine is the lightened one and it needed to be on its side so the CSM writing is sideways not up the correct way although the manual didn't mention this. Well I couldn't see it anyway. "
Let me know how it goes?
Cheers,
David
