RE: Building new 47 mono Deep V help on build please
while you rebind the Tx to Rx hold the throttle at full brake (closed carby) & this will shut the engine off if it goes out of range. make sure you can shut the engine off by pulling full back on the throttle, enscrew the idle screw & throw it away if you haven't already.
