RCU Forums - View Single Post - SR-71 Tailpipe alignment design question..
Old 09-02-2008 | 09:53 AM
highhorse's Avatar
highhorse
Default RE: SR-71 Tailpipe alignment design question..
ORIGINAL: Lance Campbell
I'm knee deep in the installation of the turbines into my scratch built SR-71, and I've got a question to pose.
I know that if I were doing, say a twin B-25, with props pulling, I'd shim the engines with 1-2 degrees of down and 1-2 degrees of inward angle on the engines. Kind of a 'toe in' approach on the engines, if you would.
Now, ponder the SR-71 with turbines mounted very far forward in the nacelles. Tailpipes are 39 inches long. When standing aft of the plane, do you think you would want the pipes to:
A. Exit a bit down from center line = down thrust
B. Pipe exits pulled together 1-2 degrees
C. Pipe exits pushed out 1-2 degrees
D. Pipe exits straight back on centerlines
E. Any combination of the above
F. I have no idea, but think they should be pointed somewhere towards the back of the plane.
Any thoughts would be appreciated.
Lance
A. Not for this configuration.
B. Absolutely NO !!
C. Should help when single engine
D. See "C"
E. See "C"
F. ;-)
G. Consider a yaw gyro for assistance during an engine failure.
H thru Z: See G.
Best wishes !!
