RE: Dietrich Extra 260 50cc
Running a Xoar 22 x 10 here. Has worked great for break-in, IMAC and most 3D. Thought about a 23x8, but decided not to, won't brake as well as the 22x10 on downlines, so really don't see the need for me to use anything else. If you're not using the manufact. recommended prop (22x10, 23x8) for break-in, what are you using? Just curious why you would be using a different size?
With that, my DPA will be in the hanger for a bit. After the 99th flt., was holding the rudder positioning it on the restraint, when I felt it wiggle. It looks like most of the hinges have come loose. [:@] None are broken, just loose. So will likely take it off and re-hinge the thing and be done with it.
